G'day all.
I'm hoping someone will have a bit of wisdom for me here.
I've got a standard 1.6 with a 32/36 DGV weber and extractors (no exhaust atm), and I'm starting to have a few issues getting her running..
let me explain.
It was all running fine before I put the extractors on, running starting everything was fine, then after I put on the extractors (removed and re-fitted the inlet mani) I went to start her up and it was all sweet. fiddle with the air fuel an idle adjusts to get her right. all good.
then a few days later, I go to start her up and it doesn't hold idle rev smoothly and generally stalls out. I could keep it alive with the throttle, but obviously not a permament fix
. I initially thought it was a vaccum leak, so I tightened up the inlet mani studs, and then I worked, but the next day ( or day after) the same problem again.
I figured I'd yank the manifold off, clean it up a bit, etc etc. I ended up using better looking (ie cleaner, better condition) studs off a junker head. I also added another washer (now there are two on each), as I thought that maybe the bolt/stud's weren't pushing the manifold in enough.
So all that's just been finished, but I'm still having troubles, the same things are happening, but I know the manifold and carby are both on tight now. (donno what torque though) I've fiddle with the air/fuel just incase it was that, but it doesn't seem to be, it's still stalling when left to it's own devices. Interestingly though, On start up, for the first 5 odd seconds, it's fine, but then starts getting eratic, and stalls. which makes me think vaccum leak still...
what could be wrong?!
can anyone spit ball with me??
anyone know whats wrong??
Any help, always appreciated
Jarred
let me explain.
. I initially thought it was a vaccum leak, so I tightened up the inlet mani studs, and then I worked, but the next day ( or day after) the same problem again.I figured I'd yank the manifold off, clean it up a bit, etc etc. I ended up using better looking (ie cleaner, better condition) studs off a junker head. I also added another washer (now there are two on each), as I thought that maybe the bolt/stud's weren't pushing the manifold in enough.
Jarred
