Drivers side engine mount bracket types?
  • Drivers side engine mount bracket types?
    I recently bought the hd engine mount kit for my mk1 from tectonics tuning.
    After comparing the mount sizes I realized that the tt mount is too big! There's a difference of something like 7-10mm between the two.
    Any any help as to where I could locate the larger bracket?
    Maybe a diesel??? im sure they had the larger mount.
      Diesel mount is different but can be cut down to suit.
      Later MK1 cabrios had them too.
      7? MK1 Caddy
      79 B1 Passat Dasher Project
      12 Amarok
        Tried TSR
        76 Mk1 4DR SOLD
        01 B5.5 Passat Wagon SOLD
        84 Mk1 GTI
          You should buy the mount including the bracket. GTI or 16v scirocco. They are both different diameters to the one you have. If you get it complete, it's much easier. Do tectonics till sell the upgraded mount complete?
            I'm fairly sure that i require the diesel sized mount. Given that it's a mk3 1.8 engine, i'll have to modify whatever I use.
            The techtonics kit only has mounts and no bracket
            Now to find a wrecking diesel...
