Okay, so I'm finally at a stage where I can start throwing money at the golf again, however because I work two jobs, I don't get much time to do proper research, so I'm hoping someone knowledgeable can help me out
if someone sources where to get all the parts from I'll send a case of beer anywhere in Aus
Okay so for my brakes, I was looking at Volksee's thread, and the VR6 calipers w/ 280mm discs looked the goods for the front. I already have machined drums with everything I need sitting on the shelf ready to put on the rear.
- Would this combo with mk3 booster and cylinder be a good match?
- What carriers would I need to use for these to match up to my mk1 hub? And where would I source them? If Volksee reads this pm me back mate, I'll buy the kit off you straight away haha.
- Where am I best sourcing mk3 brake booster and cylinder from? I know I can get some in from the uk but is there anyone locally which will be able to source one?
- I need the brake retaining springs for the rear drums which are self adjusting, I'm assuming they came from later models - does anyone have this part number?
- What are people's experiences with using poly bushes all round? Including engine mounts. I can find these kits relatively easily, is there anywhere which sells the OEM or other alternatives?
Thanks to everyone in advance, I'm sure I'll have more questions as I pursue my endeavor to be able to pull up safely haha.
