need advice on upgrading to a bigger clutch
  • need advice on upgrading to a bigger clutch
    hey guys,
    Ive got a long ratio 5 speed on my 1.8 and im looking at replacing the clutch. Im pretty sure it has the normal 190 mm clutch in it out of a 1.6, but i was wondering if its worth upsizing to the gti clutch to handle the extra power,
    im also curious if any extra parts are needed for the upgrade as i aparently need a bigger flywheel to match
    thanks
    TDI mk1 on the road!!
    I have a correct 210 mm flywheel if you need it.
      Go for the biggest one you can stretch the budget to. Its worth it when you up the power.
      MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
      "Fit the gearbox ya bum." Loon - best post ever!
