Wiring: Anyone know how to wire up a cabrio dash to the MKI
Temp is easy too, take the wire from the clocks to the temp sender unit.
If you only have a multiplug output with a handful of coloured wires, you need to know which year car the clocks are from and then look up the wire colours in the workshop manual.
19-20/6 Badgally Road, Campbelltown, 2560 02 4627 3072 or 0423 051737www.camdengti.com
Does the glovebox open up or down? The Mk 1.5 dash opens up and the earlier ones open down.
The looms are different and the connections are different.
i've done it a few times but it's been a while. I just ended up tracing the printed circuits on both instrument panels, you'll get sore eyes but atleast you'll know for sure what goes where there is actually some writing on the circuit behind the black plug (on the cabrio pannel)which will tell you what is where. It also helps if you can read german, but you can sort of figure it out . You'll need the different plug for the light switch but all the wires are colour coded the same way so if your plug (off the cabrio dash) has the wires cut and are still in the plug life should be very easy. If you're really stuck let me know and i'll pull my dash apart and have a look. I can't think of any real problems in changing.it over apart from the different mounting points for the actual dash board.
