I've got a 2e and I'm gunna bolt it up to the mk1 4 speed do I run the 2e clutch and pressure plate or mk1 or a combo of the two
2e clutch question
Depends what gearbox the 2e was previously bolted to.
There's 2 different input shaft diameters. The hole in the driven plate has to match the input shaft.
Pressure plate and flywheel should work OK, Just need to check that input shaft diameter.79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
best thing to do would be to put the mk3 210mm pressure plate and flywheel in, but buy a new clutch friction disk in 210mm for the smaller input shaft diameter (e.g suit ADZ or AAZ engine).
Then the 4 speed will bolt up but you wont have a slipping clutch because of all your 2L torque'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
