So can any of you MK1 brainiacs experienced/ solved this issue.
Its a 1471cc FD engine and has been cooling normally untill recently where suddenly in slow moving traffic its less than a hair below the red.
Changed the temp sender no change. Changed the head gasket (slight water leak before) no change. Flushed it, replaced the collant and still no change.
The water temp in the radiator appears still to be Ok as the fan operates as it always has and does not run constantly when the temp gauge is almost in the red.
Oil temp is unchanged and rearly exceeds 80 degrees
The temp sender is in the housing coming out the side of the head and goes to the the heater matrix and inlet manifold.
So it appears to be only the water coming out the head thats the problem?
Any random thoughts?
David
David
