Ok guys, on cold start the car is useless.
- Wont hold idle (i.e. will stall) and will barely hold a steady engine speed at below 2000rpm with the throttle pressed slightly (i.e. will misfire).
- It will be running VERY rich (can smell petrol fumes)
- When you do drive, its not so bad, but when coasting, it will back fire loudly every now and then
Thing is, if I drive it for 10 mins, stop the car, and start it again in a few minutes, it'll pur perfectly.
I suspect either the cold idle valve, or temperature value is the issue. The temp valve supplies vacuum to the cold idle valve at coolant temps below 13deg and should close off vacuum at above 20deg. I'm hoping if I block the pipe supplying vacuum, I can fix the issue. But I have been unable to locate this pipe.
Firstly, can anyone help identify the cold idle, and temperature valve in the below pic?
Any idea where to get a replacement?
Has anyone had any similar issues?
