Lachlans mk1 golf project.
  • #16
    update:
    i got a set of these. they've all got centre caps
    ......the pcd is 114.3
    also im going to super cheap this arvo to get an engine crane so you should see alot of updates comming soon!
    cheers
    Lachlan
    • #17
      First pic is a bad link mate, I can't fix it.
      Good news on the action. Happy to know there is an engine crane close by to me now!
      • #18
        what are the specs on the wheels? Should look the part. If the wheels are flatback would be easy enough to get them redrilled, or adapters if the offset permits
        • #19
          awesome pick up, this build will be sweet, love BBS on mk1's
          • #20
            stripped a drive shaft bolt.
            anyone got tips to get it out?
            • #21
              i've got an impact driver mate, how rounded are the corners? Give me a call if you like.
              ---------- Post added at 05:39 PM ---------- Previous post was at 02:36 PM ----------
              Originally posted by blumtns View Post
              thanks guys.
              also dont know wether or not to keep the diesel. micks convinced me a 16v is the way to go. dont know yet.
              ive got bbs rs 15x7.9 +25 comming soon.
              micks interior
              tunning art coilovers
              a bunch of pannels to replace for the rusty bits
              and ye ill get photos of my corollas tomorow.
              So these BBS are 4 stud flat backed 15x7 et25
              Perfect offset and ripe for re-drilling!
              • #22
                Put a old 12mm socket on a extension, and bash it over the bolt (if your meaning the 6 bolts that attach driveshaft to gearbox)
                Ive got a few out like this,
                <space for rent>
                • #23
                  I think the hot tip is you should use a spline drive not a allen key to begin with
                  • #24
                    this.....
                    I think ive had to remove atleast 25 of them by force
                    <space for rent>
                    • #25
                      yeh track down a spline tool, if you've used a hex they are still salvageable. Tap the spline in with a hammer and remove bolt as normal, worked for me.
                      • #26
                        ive decided to get the car painted professionally.
                        this will happen in the next month or so depending on how hectic my saving gets.
                        anyone got any ideas for paint?
                        im thinking midnight blue.
                        • #27
                          mate, use a set of vice grips, they come out no worries, I always use the grips to crack em then use the sockets
                          77 Golf tarmac rally
                          89 porsche 911
                          80 Rabbit 4dr
                          • #28
                            triple square or angle grinder
                            Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
                            White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
                            Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
                            • #29
                              Originally posted by hiho View Post
                              angle grinder
                              This would be a worst case scenario!!!
                              <space for rent>
                              • #30
                                Whatever you go with, make sure you consider wheel colour at the same time
