Hey guys, I tried searching google but nothing came up. The pic below tells it all. I want to put the fuel inlet on the right. How do I do that? is it possible? Im still pretty new to carbies so be nice
Basically you just pull the brass barb out, drill out the other side and press it back in. You have to press a plug back into the original outlet to block it off.
Sounds simple, but if you get it wrong the fitting will fall out and you risk having the car burn to the ground.
If you're less than confident about drilling the right sized hole or not being able to press the barb in, it might be best to get a carby shop to do it for you.
