Or am I just talking out of my ass? I thought I heard someone say this and I tested the coil and it reads battery voltage as in 14v... Should I put a resistor in or is that normal?
Do the mk2 16v run a 8 volt coil system?
Hey local,
Mk2 should be electronic ignition system with a 12V coil. What 16V is it?
only the points ignition models ran the lower voltage coils.
PS - if you need any advice for your car, I work in Mt Kuring-gai industrial estate.... very close to you!Last edited by gldgti; 22-09-2011, 04:54 PM.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
