OK, so I am sitting at the computer rather than anoying the neighbors with by underbody stripping efforts... my mind turns to Fuel delivery - as it does
I have the standard mk1 78 LS tank and I want to replace the mechanical stock pump with something a little more up-market. Also since this is NOT going to need to pass ADR's (restricted rally/race rego) it does not need any of the carbon canister or other junk that accounts for the 6+ hoses that come and go from the stock tank.
A couple of riders:
So I am fishing for suggestions as to what I cacn chuck out, what I can replace it with and how many of those hoses I can block off/ignore
C
BTW how DO you remove the level sensor from the tank??????
A couple of riders:
- I can/want to run fuel lines through the cabin (suitably protected of course)
There has to be a "flame and liquid proof bulkhead" between the crew area and the fuel bits
There will be a 3 mm alloy "bash plate" bolted to the underside to protect the tank from rocks and other nasties.
C
