there are two small clips that 'join' the two halves' (well, cover the join atleast) (i'm assuming you've got them off already)
Then just take them off carefully. IIRC the top one first, from the back part of the door (side of the door with the door handle in it). Pull the Vertical piece outwards, then downwards and it should come out pretty easy.
Don't worry if they bend a bit, they can be bent back pretty easily.
Drill the rivet in the door (behind the door card) that holds the sliding window channel, remove door glass (the big bit), undo the screw at the top of the sliding glass channel behind the felt crap, wiggle the vent window free and remove the whole lot from the door.
You will have seriously ass naked door by the end of this.
its usually glued on a bit. the glue is a kind of contact adhesive. its possible to remove the part (once you have taken out the quarter window rubber) by gently lifting it from below and stretching/breaking the glue. work your way along from one end to the other and back, lifting as you go.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
