Intake Setup Need Help
  • Intake Setup Need Help
    Bout ready to put my weber (32/36) on the golf, and got a few Q's
    Does it matter which way around the carb is? have googled and read to have primary furthest away from engine. opinions?
    Second, Does anyone have a pics of how their throttle links are set.
    <space for rent>
    Normally they go with the lever on the passenger side so the cable pulls from a bracket on the manifold or rocker cover.
    Here's a few I prepared earlier.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      What did you get the throttle leaver from?
      My weber didnt come with one, and the stock one wont work.
      Thanks for the pics, I see Ziggy? uses a diesel cable, is that longer then the petrol one?
      <space for rent>
        About the same length I think.
        The levers I have all came with the carbs. You can get universal ones from speed shops.
        7? MK1 Caddy
        12 Amarok
          Thanks, ill hunt around
          <space for rent>
            Picked up a universal linkage kit and bracket from ebay, love bargains
            <space for rent>
