have just swapped the old single choke vw carby for a twin choke weber DGR 32
engine is a 1991 1800 from mk 2 gti
before the swap the car ran well
now it misfires slightly on tickover
also it appears to misfire fairly badly under acceleration (partial or full throttle)
it also "runs on" for a few seconds when you switch the ignition off after a journey
when i did the swap i used a new carb to manifold mounting gasket/ plate
there does not appear to be an air leak- i have sprayed carby cleaner around the mounting when the car is running to see if any change in revs (from an air leak)
as such i think that the ignition timing is out and wonder if anyone can please answer the following for me:-
1.is the ignition too far advanced or retarded?
2. which way would i have to twist the distributor to adjust this (i.e. clockwise or anti-clockwise?)
any assistance greatfully appreciated
bb
bb
