Hey guys, as some of you may know my golf has been out of action for the past month or so.. first it was the coil.. so i replaced that.. then the day after replacing the coil myh car wouldn't fire, almost like a flat battery.. it would roll and jump start but regardless of the amount of driving around i did, it would not charge..
i have had it looked at briefly by 2 seperate auto electricians, and one deemed the battery to be fine - no problems there.. and the other ran tests and ruled out the alternator - no problems there.. when tested with the multi metre, the battery said it was fine at 12.*** valts.. b ut when i would try and turn it over, the valts would drop to 6 or below.. the only thing i can think of is that maybe i have the wrong gauge wiring from the battery to the alternator? maybe that is causing the kink in the hose? as the alternator and battery are working fine alone.. but not as a team?? let me know your thoughts..
