Electrical Problems
  • Electrical Problems
    Wondering if anyone can help on the following electrical problems, MK1 GLD
    windscreen wiper relay has failed finding it hard to source a new one,
    had low beam on one headlight with engine on (leaves parkers on only when engine stops to stop battery going flat) now I have lost both headlights and it had blown the fuse. It has one fuse for each headlight. I suspect another relay has failed but I haven't identified it yet
    Spark ignition is a threatened species
    Biodiesel is the best emission control money cant buy
    MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
    Have you tried VW for a relay? Camden GTI or Brian at GTI imports should also be able to sell you a relay
    Last resort ->
    GermanAutoParts.com
    Check this out; postage will be bugger all, you would have it in a week.
    Dave
    1990 MK2 GTI
    2009 MY10 Tiguan 147
    2010 MK6 GTI
      Relay 99 from a MK3 Golf is the same.
      Should be able to find one at the wreckers or a dealer.
      7? MK1 Caddy
      79 B1 Passat Dasher Project
      12 Amarok
        Last resort ->
        GermanAutoParts.com
        Dave
        Minimum $50 purchase to ship from GAP
        You could drop into Jaycar, they always have a big range of goodies.
        HAHAHA
          My bad; I think I must be a silent partner in GAP, I've never had an order under $200.....
          1990 MK2 GTI
          2010 MK6 GTI
            Hey mate,
            You might find that the fusebox is a bit damaged internally, you can pull it apart and try to fix the tracks if your keen (with a little prying, the whole fusebox can be taken apart).
            fuse amps function
            1 8 low beam left
            2 8 low beam right
            3 8 high beam left and warning light (on dash)
            4 8 high beam right
            5 16 rear demister
            6 8 brake lights, hazard lights
            7 8 interior light, cigarette lighter, radio
            8 8 blinkers and warning light on dash
            9 16 reverse lights, horn, fuel stop solenoid
            10 8 blower fan
            11 8 wipers, washer pump relay
            12 8 number plate lights (and dash lights i think)
            13 8 parkers right
            14 8 parkers left
            15 16 radiator fan
            '98 Mk3 Cabriolet 2.0 8V
            '99 A4 Quattro 1.8T
              hey mate the parklight will stay on with the ignition off if the indicator is left on, that could be why the park light was still on mate, the other issues make sure you get the proper relays not just generic units or they will screw the fusebox even more mate and can cause some wiring to melt (happened to me once cause the relay wasn't correct for headlights)
              77 Golf tarmac rally
              89 porsche 911
              80 Rabbit 4dr
                Does anyone know where to purchase a rear demister relay for the Mk1?
