Going to go for a electric ignition setup when new engine goes in (mk3 1.8L 8V)
I have a suitable coil ready, and i got a bunch of wiring that connects to the hall sensor? on dissy and also the ignition module.
Few questions.
Will any modules work? anyone got a part number to go by? there a few on ebay cheap
anyone got any idea how to wire it up?
Bit reading on the internets has yielded these results
looking at module and reading from right to left the numbers are
7 6 5 4 3 2 1
1 goes to Coil -
2 Ground
3 to hall sensor, closest to front of car
4 power.... (+ on coil?.. battery?)
5 hall sensor closest to firewall
6 middle wire on hall sensor
7 nothing.
Inputs, thoughts, this correct?
Also read that you need to get rid of the resistor wire from fuse box to coil.
Correct?
Seems a bit of a hassle to do all that, sure the benefits would be worth while?
Few questions.
7 6 5 4 3 2 1
1 goes to Coil -
2 Ground
7 nothing.
Correct?
