sleeved wheel bolt
  • sleeved wheel bolt
    Anyone know where to buy some??
    Ive rang pabs, super cheap ect and no go,
    looks like this
    <space for rent>
    TEFBA :: Rare wheel nuts Wheel bolts Sleeves and Locking nuts :: Frank Tonitto
    or get in contact with a fitting and turning machine shop, wouldnt be hard to make them
      I got an urge to buy stuff I don't need from that guy. Need more blokes like that making ****.
        Nice Products in Marrickille Sydney
        Nice Products
        They only sell wholesale, but a car shop local to you will be an approved distributor
          Ahhhh thanks Matt!!!
          <space for rent>
            I've probably got a set of those if you don't mind a spot of rust.
            Should come up OK if I bead blast 'em.
            $50 posted to Tassie?
            7? MK1 Caddy
            79 B1 Passat Dasher Project
            12 Amarok
              Ill take em Pete,
              Clean ya inbox, tried pm'ing you
              <space for rent>
                I think I've actually got a few different sorts of those, I'll dig 'em out and take some photos so you can see which ones would suit.
                If you've got any measurements that would help too.
                PM box cleared now.
                7? MK1 Caddy
                12 Amarok
                  ummm ive got some mags nuts without the thread obviously,
                  so going by them, the sleeved bit is about 19mm diameter and 20mm long. whole nut is 40mm long... then you would need the thread at end, so an extra 20mm is thread?
                  <space for rent>
