Ok, so it turns out I've dented the sump, and its leaking at the edge of the snout where the sump bolt is. It was a matter of time, and pretty lucky that sweet bugger all oil was lost.
Issue is very similar to what Spyda had in a post he made with his pic below.
However, the dent I have is the whole way from the front, to the back with the dent maybe 5mm inward. Can anyone comment on how close the oil pick up is and if its in-line with the 'center' of the sump where the scratches are, in the above pic?
Also, any tips on sump removal would also be appreciated. Currently reading the many sump related threads on here. As far as I can tell, its just a matter of unbolding, and bolting back with a clean surface and new gasket goo?
I'm thinking of 'JB Welding' the tiny crack so it doesn't leak and then driving it around here and there until I can source a undamaged sump.
