Its almost done damn it, there is just one last loom that I cant work out.
Everything in hooked up and working appart from the ignition coil both + and - , oil sensor, temp sensor (on the side of the block) and dizzy (plug on the side of the dizzy).
There are 6 wires coming out of the loom, some i have identified as having power and some as earth, but i cant work out where they go.
- white/purple wire
Has 7.3v all the time, goes up to 12.3v (battery) when you turn the key to start.
- Black
Has 7.3v all the time, goes up to 12.3v (battery) when you turn the key to start, but had a few conections coming off the same wire, one was conected to the back of the old motors carby and i dunno where the other conection went.
- Brown
Earth, tested with multimeter on continuity.
- Red/Black
no voltage
- Yellow/Blue
no voltage
- Blue/Black
no voltage
Ive had a search and looked for pics but no luck.
Can anyone please help?
- white/purple wire
- Black
- Brown
- Red/Black
no voltage
- Yellow/Blue
no voltage
- Blue/Black
no voltage
