just wondering its possible to link the wire that activates the starter into a relay, connected to battery. so that when i crank it over it pulls the full 12v to help turn it over?.
I know my old rolla had this setup as the starters where prone to dropping volts somewhere.
Im having the same problem in golf, it turns over as if the battery flat, but then sometimes when i crank its fine. ive noticed my volts gauge drops right down past 8v (8v is lowest it reads) So any ideas on what cause it?
Ive double checked all wires to starter, earth points ect.
edit, link found http://www.supramania.com/forums/sho...r-Relay-Mod%29
