wrecking mk1
You sure? you can have the two rear ones for $20?Originally posted by IH8 View PostAh that's okay. I'll hold out for a full set.
Thanks anyway mate.
Pretty sure they are black, not sure of condition.... but from memory, they are alright (car is at different address) $15 for the lot.Originally posted by lawny View Postwhat are the window winders like and color? cheers
It is a swallow tail, you wouldn't even bother with the engine as it's stuffed, there's a fair bit of rust throughout, but most of the panels look repairable.. if you were really keen you could probably get it on the road with a different motor and some body work for roadworthy.Originally posted by static1800 View PostHow bad is the car? that looks like a swallowtail.
Tim.Last edited by dviflx; 30-05-2010, 08:11 PM.
The inner tail light housings are good. however, the RH T-light lense is a bit damaged.Originally posted by captainvw View PostWhat are the rear lights like (interiour bulb holder side) ? if they are complete and unbroken im keen for those
are you just after the inner housings? or the complete units?
Tim
Hey Hennie, the drivers side door card is not much good (has split down the middle) but maybe repairable. passenger side should be OK. rear ones should be OK too! car is at a different address but I'm pretty sure they are beige/brown from memory. Make an offer!Originally posted by hennie View PostHow much for your door cards mate? What condition/colour are they? Also how much for the dash?
PM me and make an offer what you think is fair on the dash too.
It's in fairly good condition except for one split on the passanger side.
Once I have enough parts to gather for everyone I will make a trip down to collect. Should be within a couple of days.
Will also take pics of remaining parts.
Tim
