Hey Guys,
Seems there is something wrong with my mk1 carby, now when it stopped everything is fine but when you start the car and press down on pedal, everything else works fine except the bigger throttle arm near the choke seem to seize open and won't return, big spring is still attached and everything returning normal exept that arm, and only when the car is started (not when ignition is off) in saying that once it's stuck it takes "some persuding" to get back to normal.
Hope sombody can shed some light, i'm sure its a common problem.
hahaha. Maybe a weber or know anyoune that's got one goin cheep
.... maybe a vacuum line off or worn...
