Getting bored..
  • Getting bored..
    Hey guys,
    Getting bored of the auto box in the cabby. I love the car but the engine is letting it down!
    What would be my best option to make things more exciting..?
    - Manual gearbox conversion on the 1.8 8V
    - 2.0L 16V with manual box
    - VR6 Conversion (I've heard it's a bitch to do and is too front heavy)
    Or do I go all out and do a 20VT conversion ( I know it's not cheap)
    What do you think?
    Manual conversion on the 8V and tweak it at the same time.
      I am thinking the same, I think it is the cheapest/easiest of my options. I like the 8V tone too.
      So...for a manual conversion. I will need the following:
      Manual Gearbox
      Manual Steering Rack
      Clutch Cable
      Pressure Plate
      Bolts for Pressure Plate and Flywheel.
      Rear Gearbox Mount (As others have said, I'm not sure if the auto one is the same)
      Linkages
      Shift Rod
      Shifter Housing
      Whole lot of Redbull.
      Has anyone done a conversion before and can they confirm the parts needed?
        Yup exactly right Gavin.
        Manual Conversion is not hard in a Mk1. I`d do that first with a new clutch and rear main.
        Then when you are used to that, rip the head off, put on a UK spec big valve head, quick skim for the head and some valve stem seals.
        8v GTI is the most fun.
        You will gain about 20Hp over the stock Aussie spec 8v.
        VR6 is too hard in a Mk1.
        20VT will cost you $10k easy and will take a while.
        16v is old technology, the engines are getting pretty old and parts are expensive in OZ.
          driveshafts too, as they're diff length between auto/manual
          probably your best bet. 16V would be nice (simpler than the other options) but it all depends on money in the end.
          with a nice short ratio box you wont know yourself!
            Manual Gearbox
            5 Speed Linkages
            Manual Gearbox GTI mount for a 5 speed
            Clutch Cable
            Full German Clutch Kit
            Flywheel and bolts.
            Rear Gearbox Mount (As others have said, I'm not sure if the auto one is the same) Bracket is different, rubber is the same
            Cant remember if the front bracket is the same.
            Also you will need a starter motor for a manual kjet car as yours is different and mounts on the back, the kjet starter will also have an extra wire that carby cars dont have.
            Linkages
            Shift Rod and Housing complete
            Whole lot of Redbull. Definately
            Also Pedal Assy, get the whole column, but you can usually just hang the extra pedal onto your column.
            Also get a reinforcing plate for the clutch cable hole, they all pull through the firewall!
            And you will need a gear gaiter surround and gearknob
            Plus modify the wiring to defeat the auto lockout
            Its actually not that hard.
            We drove one in as an Auto and out as a manual in 3 hours, that was with 2 guys and a proper workshop.
            Plus the car had a manual rack already and we had all the parts ready to go.
            I reckon you should do it, Manual Mk1 GTI Cabrio FTW
              Didn't think about the driveshafts? 16V would be nice...but I think I'll look into the manual conversion on the 8v then eventually get some head work done.
              Got any parts for me Matt? I was thinking of sourcing a gearbox and parts from the UK...a donor car would be nice.
              What prices am I looking at to do a manual conversion?
                I have gearboxes, including some cheapies that will suit a budget Mk1 build.
                I have some of the shifter parts, maybe a pedal, New or Uprated clutch kits always in stock, cables obviously. Long driveshaft, but not the short one.
                I can feed you parts and advice or we can do it all for you. Call me and we`ll have a chat if you want.
                  16v
                  individual R1 throttle bodies
                  ahhh need i say more? hahaha
                  Or do what my mechanic suggested to me (add sacrasm at level of choice)
                  "dude what you want is a 2L SR20DET out of a SSS pulsar. It'd be the fastest Golf in tassie..."
                  HA HA HA.. yeah
                  2012 Ford Focus - Panther Black
                  Previous - 1977 VW Golf GLS - 2E (beige beast)
                  Previous - 1976 VW Golf Ls (flipper blue)
                    josh, the best ones are gsxr ones.
                    i'm with golf loon on this.
                    8v ftw. pants on/off fun, great drivability and economy. cheap and easily repairable/maintainable.
                    87' MK2 GTI
                    13' MK7 TDI
                      Originally posted by JoshFair View Post
                      16v
                      HA HA HA.. yeah
                      Haha, I couldn't go putting a nissan engine in there..it's just not right, german all the way!
                      jayjay I'm with you on the gsxr carbs!
                        Haha, not the same conversation I had with you a while back...
                        What is with everyone wanting 20VT conversions?
                          everyone in the mk 1 forum wants the POWAR!!!
                          either that, or they're all just dreaming! haha
                            i know i'm dreaming.. if mine went 10k's per hour i'd be stoked!! gettin bored with it sitting still out the back
                              A 16v will perform just like your 8v. It'll just have more power..
