Help needed
  • Help needed
    I am having real trouble removing the front bumper of my golf. The rear bumper was easy as the bolts were in the boot, but the front bumper is proving more difficult.
    i know that on the left (looking into the engine bay) the bolts are accessable with a little fiddling, but on the right, they are tucked away under the battery plate and next to the radiator.. i'm going to have to prop up the front and go in from benieth aren't i?
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
    Josh,
    It'll depend on which model you have...I can access both sides of my front bumper's bolts from above, but if it is fiddly for you, then from below may well be easier!!
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
      i can seem to access both of mine from up top. the one under the battery was harder but still can be done.
        Man, seems like you're struggling with simple stuff. You can reach it under the battery tray.
        My ratchet-spanners help to undo them. Before you get at them crawl underneath and soak the bolt heads and holes with WD40, then undo it the next day.
        13mm bolt heads IIRC? Or someone correct me.
          yeh from memory they are 13mm's
          ratchet ring spanners help alot. I can get them out from the top or the bottom of the car. Too easy!
            13mm yes,
            And he is stuggleing with simple stuff, but he has also mentioned he is very Car nooby haha
            <space for rent>
              i feel stupid now... hahahahaha FINE i wont ask for help!!
                Ask for help, just do it in a single thread, like your car's thread.
                  yea, clutters the forum up a lot less. I also suggest getting a haynes manual too!
                  Sometimes you have to thing out of the box with a few things, but most of a mk 1 is pretty simple.
                  Use a 13 socket with a small extension. I find it's best to stand next to the fender and facing forward (ie facing the same way as you would be driving) and excessing it that way.
                    My tip is to get the following tools together as a minimum - and you buy say Repco brand you will get a good kit for value money (not chinese cheap though)
                    Socket set - Metric 6mm - 32mm
                    Screwdriver set - Philips and Flat
                    Open ended/Ring spanner set - 6, 8, 10, 12, 13, 14, 15 should be enough
                    Hammer
                    Good trolley jack
                    That should get 90% of a mk1 apart and back together again!
                      17 & 19mm ring spanners!
                      most of a mk 1 is 10, 13, or 17mm. there's a few extra other ones in there too, say 15mm for the brake calipers and 7mm for the brake bleed nipple, or even a 19mm for the rear engine mounts. But either way, everything is pretty simple to undo, you might just have to wiggle around a bit to get at it!
                        On the topic of bolt sizes, my uncle has a very early Suzuki Carry (ute) and he always goes on about the fact that there's only two bolt-head sizes throughout the entire car: 10mm and 13mm.
                        Mike's list of tools is about all I've ever used!
                          thanks for the hints/tips. exactly what i was after
