exhaust option
  • exhaust option
    Interested to know what sort of exhaust system will suit my golf?
    it has a new lukey sports one at the moment , but the back pressure from the rear of the zorst is really powerfull about a meter of pressure,
    should i change it to a bigger diameter ??
    What diameter, pics? That backpressure comment made very little sense..
      the car is at golfwagen at the moment so cant get any measurments now but it would be about 1"3/4 ,2" ,
      Preen what im trying to say the pressure out of the rear is strong , so i think maybe i should upgrade to a bigger exhaust to have a better flow ?? cheers
        try a rear sports muffler...I went with the extractors option, but couldn't be bothered with the $ to upgrade to a 2" system thru' out, so just changed the rear...gives a nice tone with the Weber (bit like a Fiat 124 twin-cam or even a rotary, but no drone)
        Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
          mate, if i am to understand that you are trying to tell if your exhaust is big enough by feeling how far away from your exhaust tip you can feel the "breeze", then you are on the wrong track....
          2" is good for mk1.
          hope to help
          '98 Mk3 Cabriolet 2.0 8V
          '99 A4 Quattro 1.8T
            2" is good for mk1.
            hope to help
            What he said..^^^^
              Originally posted by Preen59 View Post
              What he said..^^^^
              yep! some generic extractors and 2" exhaust with a hot dog and straight through fibre packed rear muffler. (to be a bit more specific)
                its a kjet injection !
                simalar to a set up for a weber ect.... ?
                  I got extractors with 2" pipe, one hotdog muffler, and a rear muffler.
                  is resonably loud. but sounds so right
                  <space for rent>
                    yea, that same exhaust will work perfect!
                      It looks like we all have the same setup!
                      My 1.8 Kjet is running extractors & a 2 inch mandrel bent system including a hotdog resonator & straight through muffler..
                      I'm actually looking at a quieter muffler and some sound deadening as the drone is killing my ears... around town its ok, but if I'm in the car for long trips I have to wear ear plugs
                      76' 2dr Kjet
                        I thought ear plugs were standard issue with MK1 registration renewals?
                          A set of 4-2-1 extractors with a 2" full system & reasonable sized hotdog & high flow muffler is the norm for a stock to mild mk1 I reckon, but can get droney at times. Especially if some of you have fancy upturned, dump pipe, curnved exhaust tips & this is where you can make the drone worse. I like to go for a as straight as possible rear section from the rear muffler to the tip to avoid this.
                          Above & beyond mild, you really should start looking at 2 1/4"+ high flow system.
                          I call mild upto 160-170hp.
                          There are a couple of ways you can tone it down though.
                          Try a rear offset high flow muffler
                          Try a multi chambered reverse flow rear muffler, but this can reduce flow. Not really a big deal on these size engines. But it will decrease noise substantially!
                          Try a new designed "proper" performance muffler like a Hooker Aero Chamber or Flowmaster 44. These are straight through, but direct the gas through various shapes to reduce noise.
                          They may look restrictive, but they are far from it. Several friends have the aero chambers fitted to there cars & these cars are making from 500-1200+hp without problems at all.
                          They maybe expensive, but are well worth it I reckon. Over kill on these vehicles as they just don't make the power to justify these mufflers
                          The other option is fit a turbo! haha. You not only get upto twice the power (sometimes more), but the car becomes alot quieter too! haha No more drone either!
                          I currently run a full mandrel system incl. a 3" dump pipe into a full 2.5" straight through system with a hotdog & high flow rear muffler.
                            Very impressed, you got it in one! I've got a twin 2' DTM tip
                            Awesome, thanks for the info golfworx.
                            I'm pretty keen to get some more opinions on these types of mufflers as an exy muffler isn't in my budget at the moment.
                            I was about to get my mechanic to swap my straight through for either a;
                            -dog leg (90 degree bend in muffler) ..is this what you mean by rear offset?
                            OR
                            -a reverse flow (2 x 180 degree bends)
                            I know I'll probably cop a bollocking for this, but drive-ability is important to me for my daily..
                            I don't like the attention I get from ringin' it out... its too f#%king loud! I find I drive harder wearing earplugs cause I can't hear the damn thing
                            76' 2dr Kjet
                              Don't worry Simon, I'll forgive you that, cause you do actually drive it daily! and mod & repair it over weekends and overnight as it is your only car! big props!
                              I' actually really like the standard exhaust on my diesel, it isn't loud, which is something a bit different after my last two cars!
