First of all, read the Haynes Manual, and browsed for hour or so on here...
Problem is, i had to replace a cracked camshaft wheel on my spare 1.8L.
now ive aligned the camwheel line to the rocker cover as said in manual. have aligned the v notch on crank to the dot on the itermediate shaft wheel.
Now this is the tricky bit, when i go to tension the belt the crank and the other wheel move out of alignment.
Any tips on how to stop this? if i manage to get it one tooth out, what will happen? im guessing all this has to be spot on?
Ahwell, back off to read some more,
