Broken it
  • Broken it
    Yes, after two years nearly of faithful service I broke the dub for the 2nd time. First time sheared the bolts holding on the steering rack. Dont ask how I did that
    Conked out today at the traffic lights, luckily coasted into a servo.
    No power to fuel pump, fires up when injecting fuel straight into carb, Fires up when using seperate power to fire up the fuel pump.FP relay operational.
    At the garage being sorted, hopefully back on the road tomorrow.
    Been demoted in the mean-time to a
    Wait for it.
    Yellow.
    Highundies Getz
    It is a sad shocking car to sit in and drive...Pure tasteless junk.
    Please all pray for me , so I can yet again get back into a real car..
    1993 MK1 CAB ! Work in Progress........
    good luck man! hope you get out of the gaeytz asap!
    dom
      Bad luck mate, hope you sort it out soon...
      dom
      Hey the Getz isn't a bad car!
        this coming from a lada lover lol
        dom
          dom
          Both equally good cars... well, no the getz is many times better than the Lada lol...
            hopefully its just a fuse.
            congrats on breaking yours, im still trying to break mine, but it just wont......no matter how lean it runs.....
            2008 POLO GTI - SOLD
            2005 MkV Golf GTI - couldn't resist
              The lada and Hyundies are shockers. They are crap, don't dig a hole and try to justify anything different..
              Do you English brothers remember the FSO polonez...Now that is a proper car :eek
                Could be the fuse although the fuse blowing can be a sign that the pump is on the way out.
                What happens is that the as the bearings in the pump wear out the pump can sieze momentarily causing a high current draw and thus blowing the fuse.
                I know this because my car came with a packet of fuses in the glovebox and a habit of blowing them mid corner at full throttle.. A new pump fixed the problem.
                Pete
                7? MK1 Caddy
                79 B1 Passat Dasher Project
                12 Amarok
                  Do a skid in the getz and get video of it
                  Ghetto-Rennen
                    Thanks Peter. We ascertained the fuses are OK, however I have no battery light, but when you wiggle the key in the ignition barrel the battery ligh comes back on and it starts, apperently their is a switch in their that feeds other things which feed the pump. Thats where we are going to start first.
                    Mika the Getz won't do a skid, even with low treaded tyres, it just doesn't have the power.....
                    It does have oversteer though and going round corners you can feel the tyres sidewall flexing. Its not a nice feeling..I am used to the ligh and low dub, whcih travels corners very well, so I had to readjust my throttle foot when I got in the getz, to accomodate the crap cornerning.
                    Its a croc of S%$#@
                      Originally posted by Brisben View Post
                      Its a croc of S%$#@
                      You said it, haha.
                      Good luck with the cabby mate!
                        Ben,
                        Sorry to hear the bad news. Hopefully nothing major and back on the streets soon. Let's hope it's not too expensive either.
                        Where are you getting car looked at?
                          still broken ,
                            still broken ,
                            oh dear. I have no power supply to the fuel pump in the fuel tank. Dizzie changed , relay changed, ignition switch changed still nothing, starts straight away if pump is powered by a seperate supply, however after about 15 seconds something sends a signal and turns the pump off again, thus stopping the engine. At a loss here, only option is to run a new relay and supply.
                            Anyone in the know how got any thoughts or ideas what this strange and frustrating problem could be ??
                              Ben-dude!
                              Get yourself a new fuel pump relay - HSY at Colmslie got me sorted with one. Avoid the power supply unless you are certain that the relay is OK and that the pump runs off an independent supply (pull battery out, get under the car, disconnect the power leads (to avoid blowing power supply and your new relay) and fire it up with the battery connected to a few long strands of wire, connect to pump first using at least 1 mtr of cable for each terminal of the pump, then connect to battery with you clear of the underbody of the car by wrapping earth (-) around like battery terminal and then touching + terminal with + lead without wrapping, if it buzzes you know you have a power supply issue, if it doesn't buzz - new pump perhaps and $$$(be careful not to short out and definitely DO NOT TRY if you smell fuel around the pump)
                              The bolt on the steering rack - mate that is a first in my books as well, jot that down to a new discovery!
                              Also might be a good idea to replace the ignition switch - again you might get one from HSY and they are relatively easy to replace with a few hours of focus, patience and good instructions, try the Haynes or Bentley Manuals for guidance as you need to drill out a few shear bolts.
                              Good luck mate
                              1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
                              1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
                              1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
                              1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
