Engine removal
  • Engine removal
    despite being able to r&r aircooled motors with my eyes closed, I've never removed a VAG watercooled motor.
    Question: do you need to remove g'box as well, if just doing an engine swap??
    and if so, where the best place in inner Melbourne to buy cv joint spline tools
    (All tools ??)
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Yup, take the box out with it.
    Id undoo the gearbox mount, whilst holding it with a jack or crane, then the rear and front mounts, then the timing belt one when it is canted down at an angle.
    Drop it out through the bottom.
    Reverse order to put back in.
    You will need M8 Spline tool for the driveshafts.
      Yep, I've seen the M8 spline bits at All Tools .
      As Matt says it's easiest to remove and replace motor and box together.
      Motor and box can come out either up or down just depends on what lifting kit you've got handy. Where you seperate the exhaust might determine whether you go up or down.
      Pete
      7? MK1 Caddy
      79 B1 Passat Dasher Project
      12 Amarok
        Thanks guys. I picked up one at All Tools Sth. Melbourne at lunch..(their last one too !!)
