It’s so damn close to being roadworthy that these last couple of things are painfully annoying.
I have managed to get the wipers to do all the things they are suposta do apart from return back to the bottom of the windscreen. We've replaced the stalk, the motor and relay #19 in slot M and #53 in slot K. I’ve also opened up the fuse box and it looks brand new inside. They wipe when you spray and have the 3 speed settings, but they don't go back to the bottom of the windscreen when you switch them off, they just stop. Any ideas?
One other major problem was that the carbie was sucking in extra air with the fuel making it almost impossible to start and drive. We found that one of the fuel lines from the pump had a crack in it, replaced that and it runs fine. The problem now is that when you put it in to a gear other than park or neutral the idle drops to about 500rpm. It sounds like it will stall but it doesn’t. Also when you rev it in park/neutral the idle will stick at about 1500 - 2000rpm then settle back down to 900-1000rpm (just like the mk2 haha
). I also know very little about carbies so I really don’t know what to do. Here are a couple of pics of the carbie, my dad sugested that the choak is busted.
on how to set the idle up correctly. The idle is now good and sits at 900rpm and it doesnt stick anymore when you rev the engine.
