Is a standard 1976 5 door golf an LS?
  • #16
    So has anyone heard of a '77 Golf Convertible?
    When I google"vw golf convertible history"it's indicated they were first built in '79.
    I had a look at a convertible today that was complianced as built 5/77.
    Obviously someone here will know the facts.
    It was fitted with a 1.6 carbie/4 speed man.
    Body was r/s unfortunately.The rest was all there if a bit worn.
    "That's what she said"
    • #17
      probably a backyard choptop
      there are a few of them floating around
      • #18
        I may have mentioned this before, but when I first got my golf I kept seeing a white convertible MK1 with the reg only one number different from mine (original '76 plates). So people have taken to them with a can opener before. In an old thread someone said that they are even worse than chop-top Beetles, so stay clear. Chop-tops/convertibles are different from factory Cabriolets. They were later than regular MK1s.
        '76 Mk1 Golf - Gone!
        '05 Mk5 2.0 FSI Sportline
        • #19
          I guess so.
          It was suffering terminal cancer so I didn't waste too much time checking it out.
          • #20
            the proper cabby's have thicker sills amongst other things to help cope with the lack of rigidity provided by the roof. that's why they're 300 odd KGs heavier.
            • #21
              This "convertible" did have thick sills.
              It had what looked like a square hollow section beam beneath where the normal sill is.
              The beams did look bodgie as there was a seem weld running along the length of the beam as if someone had welded 2 C channels together to form the square shaped beam.Didn't look Factory Standard to say the least.
