Where to get front discs?
  • Where to get front discs?
    Howdy,
    Does anyone know where I can get a set of front discs for my new MK1 GLS. (Apart from germanautoparts.com)
    Apparently the one's I've got are too thin for a RWC.
    Thanks!
    A brake shop. Seriously.
    Most of the good brake places can get them in.
    I use Better Brakes in Bayswater.
    Theres 2 types, basically petrol and diesel.
    The petrol ones start off life 12mm thick and can go down to 10mm before they/re unroadworthy.
    The diesel ones are 10mm wih a limit of 8mm.
    (There's also GTI ones which are vented - 22mm thick with a limit of 20mm IIRC)
    Make sure you know what type you're after and hop on the phone. You'll soon track them down. Even supercheap could probbly order them in.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      Cheers Pete,
      Sound like the way to go.
        If you get stuck i've probably got a 2nd hand set here somewhere.
        Pete
        7? MK1 Caddy
        12 Amarok
          any parts shop....RDA and DBA make them, i got mine early this year, cost was well under $100 for the pair.
          2008 POLO GTI - SOLD
          2005 MkV Golf GTI - couldn't resist
            Originally posted by hessiethecrab View Post
            Howdy,
            Thanks!
            I expect them to be readily available through a VW specialist or parts supplier (eg Volkspower)
              $84 for the pair
              $76 for the pair
              $88 for the pair
              GSL RallySport 1300 884 836
              Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
              QFM Performance Pads
                Thanks everyone.
                I ended up just getting some from pick-a-part that were still 12mm.
