power steering conversion
  • power steering conversion
    im chasing info on a power steering conversion for a mark 1 golf, i know they do it in the uk, does anyone here have info or have done this themselves?
    One Thousand Pounds for a TSR Power Steer Kit, in the UK although they dont make em anymore.
    Or bodgy something up, but it will then need engineering.
    I reckon a Mk2 or 3 rack would fit with some custom bracketry, I`d also like to hear from anyone that has done it.
      hey thanks for the info, its actually for a friend and the golf is used for rallying
        I started to reply with some negative references to the numerous times this question had been asked But than I remembered a conversation with Steve (20valvekitcar) who said he had sucessfully used a mk3 rack, then there is the green (frog) mk1 that Matthias built that seems to have an electric PS pump fitted (no idea as to the rack) so I guess that there may still be options other than the now extinct TSR kit.
        But aside from all that who else is going to be rallying a Mk2???
        I thought I was the only one prepping a car this side of Victoria?
        Charles.
        It's been a while...
          posted this ages ago if you can be bothered digging out old posts..
          A mate here used a Mazda 323 ps rack in his Mk1 autocrosser ( benger circuit)
          apparently its the right width, and the tapers match the VW steering knuckles..
          dunno what he used as a pump, but it would be academic anyway as long as the pressure relief was set accordingly..
          the car was running a locked diff + steering brake..
          HTH..
          Lots of MK 1 Scirocco's...
          Cheers,
          Grant...
