Ah-Hem! Two words people - Flat Slide!!!!!
Carbie suggestions
Carbs
No carb could ever compete with todays after market computers.The power and economy I get with my 20vt,not to mention the driveability, is decades ahead of any Fred Flinstone fuel metering device that relies on suction to get the mixture close. In saying that, nothing beats the sound of twin or triple sidedraughts on full song.Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Originally posted by aprr32In saying that, nothing beats the sound of twin or triple sidedraughts on full song.sigpic Camden GTI Performance. VW / AUDI Specialists
Originally posted by aprr32decades ahead of any Fred Flinstone fuel metering device that relies on suction to get the mixture close.
(flat slide!!!!)MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
"Fit the gearbox ya bum." Loon - best post ever!
its very true.... but who can be bothered? not me, hehe.
nah respect to you guys who have the patience to deal with things that have mixture. myself, i prefer the simplicity of the equation air + diesel = bang in all combinations....
then all i need to do is build my little diesel strong enough to take 30psi, and it'll outpull nearly everything.
(audi's winning diesel LeMans car this year.... mwahahahahaha)'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Interesting debate. Despite the fact that I'm running K-Jet these days, most of my Golf experience is with carbs - everything from single throat Solex, DGAV, single sidedraft Dellorto to twin sidedraft Webbers.
Ok, lets see - Solex to DGAV - no brainerEngine now breathes... better with a decent cam of course (when second throath cuts in).
Problem with single sidedraft is the depth of the manaifold + carb - twin carb manifold is quite a bit shorter.
Twin '40s are great for road use, and semi-serious competition. Good choice for a warm 1600. IMHO, you only need '45s for serious track use (with a hot engine). Of course, I'm not about the admit to why I've got some '48s tucked away in the garage!
Sorry Golf Loon, twin sidedrafts with a meaty cam beats a blow-off valve hands down I reckon for aural effectEnough to to send shivers down your spine. Funny that they sound quite different on a Golf than other engines though...
My advice - try a DGAV first, and then (later) go to twin sidedrafts.
The Latest...
OK, after a flurry of e-bay activity I ended up with all the bits (or so I thought) I needed for the upgrade.
I decided (after some CVWC advice) to open up the top of the manifold to increase the mouth area and make a better match with the spacer. Unbolted the existing carb and manifold and bolted the new manifold on. Re-did the necessary plumbing mounted the new Weber (next time I will fit the carbie first!!) and was ready to test.
After a few minutes of cranking, there was enough petrol flowing over the top of the Weber to make me worried about the entire thing going up in flames. So….. pull the cover off the 32/36 (the choke connection makes this an interesting experience) and discover that one of the floats is no longer soldered to the other, and the flooding makes me suspicious of the condition of the gaskets. Soldering is the easy part, finding a Weber gasket kit on a Sunday arvo would be more of a challenge. AutoPro at Belconnnen found a kit at their Phillip store – so after a quick fang down south I had what I needed. Long story short, I stuck the carbie back together and re-plumbed the return line (something previous owner had deleted – this may have been a mistake) and away she went. Wahoo!!
Took her for a test drive and was a little disappointed: Once warm, idle was a struggle (better with some choke applied) and she was starving at anything above 5k revs (could this be the curse of the reinstalled return line?), also noticeable “popping” on overrun (while cool, not sure it is a good thing) both with and without vac advance line attached to the dizzy. So I figure that I need to take her to someone that can tune and maybe re-jet the carbie…….
Anything I missed??
It's been a while...
Is your return line too big?
A restrictor of some sort usually helps. Plastic bead in the line in a moment of need
Nice work on the Sunday arvo dashsigpic Camden GTI Performance. VW / AUDI Specialists
Originally posted by blackgti1.8Sorry Golf Loon, twin sidedrafts with a meaty cam beats a blow-off valve hands down I reckon for aural effectEnough to to send shivers down your spine. Funny that they sound quite different on a Golf than other engines though...
Well there's your problem...
In frustration I went shopping (again) and grabbed a presure regulator. I re-sealed the return line and decided to rely on the reg instead. THEN I turned my attention to the cr@p idle issue. No amount of twiddling the adjust screw made any difference!! so... lets rip out the idle jet and have a look.
Ah, the chunk of blue junk in the end of the jet could explain much.
After some cleaning we have idle!!!
A quick test drive and the smiles were starting, man when that second throat kicks in it is like NOS (well not really but you understand).
OK last thing to address is the flat spot when planting foot hard (I mean hard) easy footage worked fine...
Csigpic
Glad you got it sorted Charles
I always have to rebuild carbys twice too. something to do with loving it too much the first time, or residual crap in the system
Could the flatspot be solve by upping the pressure reg a bit?sigpic Camden GTI Performance. VW / AUDI Specialists
