electrical problem
  • electrical problem
    hey guys
    as some know i had a little bit of an elec problem a few months back
    well some of us thought it has to do with the ignition switch,
    well its starting again, the issue is, as im driving the battery light will come on, now when it comes on, i cant stop and idle at a set of lights as it will stall......
    so as i was cruising down the street and the battery light came on, i actually tried tapping the dashboard, funnily enought the light switched off and the car could stay running at a set of lights?!?!?!?!
    i have now narrowed it down to wires or something playing up in the dashboard but have no idea what it could be? when the battery light comes on its like i have turned off the ignition and kept driving....... if i come to a stop..... the motor dies, also if im cruising and take my foot off the pedal, it has a sharper decelleration compared to the normal foot off the pedal
    any ideas would be great as i would like to get this fixed coz its the only annoying problem on the car!!!!
    thankyou
    dom
    Wires get crossed behind the dash?
      Have you checked the alternator yet? Can't hurt to put a voltmeter across the batt to determine the alt is still working proper.
      that's where I'd start anyways. Then I'd start pulling the dash apart...
        What about the coil also ?
        1993 MK1 CAB ! Work in Progress........
          Hey Dom, this is the same issue I am having with my car! My battery light is constantly on, esp at night when the light are on. Only difference is that I think its a mix of alternator and carb issue as once it is warmed up it drives almost normally.
          I tested my alternator yesterday and sure enough, its undercharging, ill bring my gizmo on wednesday and we can check yours out.
            My battery light goes on when I first kick the car over, however give it a little boot over 1200rpms and it goes off
              yeah thats normal mate, the altinator kicks in when you rev it....
              dom
                dom
                Woohoo to normalness
