Help - Brake lights dont work!
  • Help - Brake lights dont work!
    Ive noticed that for the past week both my brake lights dont work.
    I checked both bulbs they are fine.
    Did a check on the fuse box all looks good there as well?
    What number fuse controls brake lights?
    What else should i look at?
    I dont think its my tail lights as both Parker, reverse and indicators work....
    Very weird!
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    brake light switch on master cylinder?
    MK4 GTI (KO4, GIAC)
    VW Kombi Ute 2ltr EFI
    Audi 90 20V Quattro
      I'd get a new brake switch on the master cylinder. I guess you can probably check them some how so you don't buy one to find out it's not the problem.
      mk2 GTi 16v
      Corrado G60
        Ha ha beat me to it.
        mk2 GTi 16v
        Corrado G60
          where abouts is the switch located?
            you got a haynes manual?
              no manual anyone got pics?
                There's two switches with plugs directly on the master cylinder itself.
                  Bridge the wires
                  Take off the plugs and get a piece of wire. Bridge the spade connectors and it the brake lights come on the switch is U/S. A have a couple if you need one. PM me.
                    I had a diesel a few years ago that I had trouble with. Had a "phantom" voltage to the switch. Connected a test light to the switch and it lit up with the foot on the pedal but wouldn't light up down the rear. Ended up running another power supply wire to the switch and that fixed them. New switches are usually, 3 pin, $13 or 2 pin, $10 roughly. Cheers, and very easy to check!
                      I pulled out the 2 wires that go into the switch. And replugged them still nothing. I have a spare Master cylinder lying around so ill check if a switch is on there that i can pull off.
                      cheers let u know how i go!
                        Like Brackie said Costa.
                        There are two switches on the M/C, in case one fails. Usually both fail and then you have no brakelights.
                        Check with a bit of wire and replace the switch.
                          Another option is to just wire a mechanical switch directly onto the brake pedal.
                          The Mk1 brakes lights aren't too good at the best of times.
                            Golfworx has the idea...
                            This is the way mine have been for 20 + years... Between VW's reverse light switch and brake light switch they couldnt get it right...
                            Lots of MK 1 Scirocco's...
                            Cheers,
                            Grant...
                              all sorted tried the ire trick on the brake switch no lights.
                              So i called Matt and he said its the Fuses for sure.
                              Played with the fuses and now its all sorted thanx guys!!!!
