couple of electrical issues
  • couple of electrical issues
    well, i start to work out several non-working lights in the cluster, they don't affect the car but I just feel something is missing
    First is parking brake light not working. people in other forum mention there is a switch under the handbrake, but I couldn't find any. Is this something diff from aus mk1 and other country ?
    Is there any fuse involved, pls help
    76ers didnt have the light. Someone must have fitted a later instrument panel.
      My '76 has no handbrake light either.
        good for fooling your passenger at night about sudden u-turns.....
        '98 Mk3 Cabriolet 2.0 8V
        '99 A4 Quattro 1.8T
          The cluster is pretty dim by modern standards so you will definitely notice when they are missing. Easy to change one the cluster is out..
            Really ? i roughly remember it went ON sometime ago....
              I caught myself driving with the brake on, no lights, so I am assuming no...
                If its a 76er, once again, they didnt come out with the handbrake warning light, if its a locally assembled. The German 76 GLS models had the light from memory and I have only seen 1-2 of them.
                If it worked once then someone has fitted a GLS cluster and wired it up. If it is wired up then it may be dodgy as the ones with the light also had a problem light in the same unit and the wiring for them is a bit more extensive
                  I hope you didnt do that with Imps too mate.
