Mk 1 - fuse/relay panel replacement?
  • Mk 1 - fuse/relay panel replacement?
    Where can I get a new/another fuse & relay panel?
    Just started on my Mk1.
    Lights and wipers not working too well.
    Tracked it back to the fuse/relay panel, after checking everything else.
    Have replaced column switch and relays, overhauled wiper motor.
    1978 Golf Mk1 - 4 door
    Work in progress
    John C aka oldplodder
    I have some decent second hand ones, but you can crack your one open and clean / resolder any dodgy bits and it may work.
      I have one new one left to suit your Golf. Pretty expensive and difficult to find these days though.
      PM me if you are interested,
      Andrew
        Andrew
        Agree they are expensive. You can still get them from VW Australia if you've got a lazy $400 or so. I got mine from GermanAutoParts.com a bit earlier this year. It was about $US90.
        Greg
        2002 New Beetle Turbo
          Thanks, might give the solder a go, but will be in touch in I need to.
          Work in progress
            price now seems to be $103.50 and is listed under "rabbit"
            '98 Mk3 Cabriolet 2.0 8V
            '99 A4 Quattro 1.8T
              on ebay at a steal....
              http://cgi.ebay.com.au/VW-Fuse-Box-Unidentified-Probably-Mk-1-Golf_W0QQitemZ230318387513QQcmdZViewItemQQptZAU_Ca r_Parts_Accessories?hash=item230318387513&_trksid= p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A 1318
                Not a MK1 fuse box. LAte Beetle at a guess.
                Pete
                7? MK1 Caddy
                79 B1 Passat Dasher Project
                12 Amarok
                  $290 Aust for the new one here.
                    well you would definitely give it a bash with cleaning and soldering contacts up wouldn't ya?
                    prior to forkin up ya cash.....lol
                    gee they are abit $$$ ching ching
                      Worth a try, for sure. I have seen a couple of successful repairs over the years.
                      I am not here to sell stuff but to help keep these things alive. Nothing nicer than a new fusebox when you replace them though. Horn, wipers and lights are soooo much better! No more intermittent indicator problems.
                      My caddy has a totally different setup completely.
                        yeah chucking in new bits is much less concerning, I'm liking those Mk1's they look A1 in white!!
