Hey guys
Trying to get the old girl back on the rd as she hasnt been doing much.
Wont idle unless I have the choke fully open. When I go to accelerate it splutters and pops. It only drives normal when I have the throttle wide open, as soon as you back off and coast it starts to shutter/splutter VERY bad (like its running on 3 cylinders.. or even 2!) feels like it has a flat spot when u very lighty touch the throttle, then I press a bit harder and it pops into life like i just hit full boost.
I replaced the fuel filter and all spark plugs to no avail. I was thinking some sort of fuel problem.. busted fuel pump maybe? But that wouldnt explain why it idles on full choke would it?
Is there a way to test the fuel pump without replacing it?
Any other suggestions as to the cause
cheers
Lee
cheers
Lee
 Hi. Which one is it, the orange Golf? A  worn out fuel pump wouldn't allow it to rev. Could be a large air leak or only the wire off the air cutoff valve. That wire can breayand also not supply voltage to the jet. They generally don't run below 1500 RPM  when that happens.
