Thermo fan NOT WORKING
  • Thermo fan NOT WORKING
    my thermo fans not working and im at a loss as to why, because it worked just fine before i did the engine swap.
    any ideas? i've checked out 2 fans, bipassed the radiator switch to hard wire it and both dont work, maybe a fuse?
    cheers
    Yeah grab a meter and make sure you've got power dude.
      They are the most simply wired thing on the mk1s.
      Power to fan and negative switching through the thermo switch!!
      Andrew
        will do mate
          Andrew
          ARGGHH i hate wiring mate
            If there's no power check your fuses, mine was wired to the one on the far right.
            Pete
            7? MK1 Caddy
            79 B1 Passat Dasher Project
            12 Amarok
              cheers ill check it out, hopefully its just a fuse
                if its not a fuse, check your plugs in the back the fuses
                that was the cause of mine not working
                  cheers chaps, will do tommorow in the light
                    Doing an engine swap is more than enough of a reason to stop things working!!!
                    I'm sure there's just no power at the connector, as others have said. Pull a supply voltage straight off the battery and see what happens
                      i know, everything could be working juusssttt fine before the swap and as soon as you wack the other one in.... BAM problems everywhere.
                      cheers Stu, will do that after checking the fuse
