Yes, I've been reading about the missing GP-light. The GP-light supposedly indicates that the ECU is fully on. A failure of GP-light is usually caused by faulty relay 109, according to the DIY on TDIclub. 109 gives main power to ECU. I pulled the 109 and bench-checked it. It was nice and clean inside, with no visible corruption, and clicked fine, both at room-temperature, and when heated with a dryer.
Oil buzzer, no light, shaky tachometer, dies when hot - 1.9 TDI ALH
must be something other than the relay then. All the symptoms you describe would seem to indicate an intermittent electrical fault... thats why I suggested ignition switch.Last edited by gldgti; 15-08-2017, 08:50 PM.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I replaced the 109-relay. That seems to have corrected the problem. There is no GP-light-delay when twisting the key any more, and it starts and drives nicely. Been driving it for somewhat more than two hours on steep inclines, with no incident thus far.
