Hi everyone,
Am having trouble with my 2009 GT Sport TDI, the car has a 42DD intake & MAF de-grid, bluefin tune, and recently a straight pipe from the DPF back (removed the res and muffler).
Since doing the exhaust, I have been having a squiggly light popup, (had it once before), however the past week it has been coming up every single drive.
I just ran a scan with VCDS and came up with the following two faults on the engine, could anyone shed some light on these or do I need to go to a mechanic? (if so can anyone recommend someone that knows what they are doing on VW diesels in Melbourne?)
Code:
Address 01: Engine Labels: 03G-906-018-BMN.clb Part No SW: 03G 906 018 FC HW: 03G 906 018 FC Component: R4 2.0l PPD1.2 G 1879 Revision: --H52--- Serial number: VWX7Z0H23NVXXX Coding: 0000078 Shop #: WSC 06441 785 00200 VCID: 6BFB1A5C4A683B190A-803E 2 Faults Found: 005214 - Mass Air Flow during Regeneration too Low P145E - 006 - - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 4 Reset counter: 38 Mileage: 140XXX km Time Indication: 0 Date: 2000.00.00 Time: 00:34:34 Freeze Frame: RPM: 2080 /min Torque: 32.0 Nm Speed: 105.0 km/h 0.00 % 11.31 % Mass Air / Rev.: 321.6 mg/str Mass Air / Rev.: 594.1 mg/str 012600 - Intake Manifold Runner Control P3138 - 006 - Regulation Deviation - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 5 Fault Frequency: 5 Reset counter: 40 Mileage: 140XXX km Time Indication: 0 Date: 2000.00.00 Time: 17:24:12 Freeze Frame: RPM: 2496 /min Torque: 96.0 Nm Speed: 97.0 km/h Mass Air / Rev.: 436.0 mg/str Mass Air / Rev.: 583.1 mg/str Lambda: -21.9 % Text: Kein Messwert verfuegbar Readiness: N/A
