Golf Tdi Issues !!!
  • Golf Tdi Issues !!!
    Hi All,
    I'm looking at buying a new Golf TDI or maybe a TDI GT Sport and was wondering if there have been any mechanical problems with either of these models. I wouldn't expect too many on a new car especially a VW as I have always considered them to be very well built and engineered.
    Russ
    Russ
    As far as the engine goes i have had zero problems with my Caddy TDI, and it's a fantastic vehicle too. Faultless.
    No, wait, there is one problem..
    It's too high. But i'm fixing that.
    The golf TDI's that i have been in were fantastic cars if you ask me. and the GT sport screams!
      I have this problem with my TDI in that I used to really enjoy going to service stations to fill up, and now I hardly ever have to go to one.
      MY08 Jetta TDI, DSG, Platinum Grey, Anthracite Leather, Foglights
      MY07 Polo TDI, Reflex Silver, GTI Wheels, GTI Suspension
        Thanks for the quick response. I am really amazed at the grunt these new common rail TD's have. I have test driven a Ford Focus TDCI and a Hyundai i30 (sorry for using unsuitable language on a VW site) The Focus really flies compared to the i30, but the overall finish of the Hyundai is far better. Can't wait for the VW test drive hopefully this week sometime I will be trying out a Manual TDI Pacific and if they have one in stock I won't be able to resist taking a GT Sport for a spin. Haven't been able to find anyone with anything bad to say about them so far.
        Russ
        Russ
          If only all of life's problems were so dramatic .......
          Russ
            Haha, yeah i get a shock nearly every time i fill up cos fuel has gone up by so much since last time!
              Russ
              VW does not use Common Rail TDI yet in the Golf range it uses a direct injection system called 'Pumpe Duse'.
              The next Golf will have the new Common Rail TDI engines
              - Ben
              2008 Jetta 2.0L FSI
                Thanks for that, I just did a quick search on the Pumpe Düse system as you said and it looks as though it works along the same lines as the common rail system, but with maybe the result of a slightly quieter engine. Either way from what I have read they seem to perform just as well and the TDI GT Sport has got me drooling for a test drive
                Russ
                  Yep, just make sure and try out the Manual and the DSG if u get a chance. Ive driven Manuals all my life, until now. While it still has some annoyances, and doesnt change exactly where i would, its pretty close 99% of the time. The GT has the paddle shift while the pacific doesnt.
                  currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
                  previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
                    Hi,
                    Does the DSG have the usual automatic trait of kicking back into a very low gear when you plant it and seemingly sound like you're going to blow the head off it. I have a 2005 XR6 Falcon with the 4spd tiptronic at the moment and although when it kicks back it revs pretty high it doesn't sound like a 4 cylinder auto would (ie - ready to explode in a pile of bolts) that's the main thing I dislike about auto's.
                    Russ
                    Russ
                      Hi Russ,
                      I'd have to add my 0.02c.
                      I chose the manual GT and that was stepping out of a 4 speed auto BA GT. Whilst you sure have to actually "drive" the manual diesel, I hate to tell you that there'd be nothing between your current XR6 and my weezy 2.0 diesel in a traffic light drag. Sure I have to drive the ringer out of it to match the current auto 6 packs, but I've found through repeated attempts that these things are "about" the same speed as the 6 cylinders in a drag, and make even the 8's and similar beasty cars look silly in the twisty, hilly stuff. About the only difference is the transition to FWD, wheel hops at the lights, and power on understeer, which is all to easy with a genuine 350nm at the wheels!
                      Having had Ford Auto's for the prior 7 years, it's been a breath of fresh air to get back into a manual. The downside for me is that I can't really just "cruise" elbow out the window style as I'm ALWAYS changing gears in traffic, but the upside is I get to choose what the car does in the hills and odd squirt in the twisties. THAT for me is the winner. I'm sure DSG is 99% as good as previuosly mentioned.
                      I've not lived with a DSG though, so perhaps once a few of the DSG oilers chip in, you'll get a good idea of the real story. Also, sadly, Jaymz on here is looking to sell his as new tricked up GT, so in your shoes I'd be checking out that option in the "For Sale" section. I've driven it, and it just rocks.
                      You won't miss much about the Ford, whatever way you go, trust me!!
                        Hi,
                        Russ
                        No the DSG doesn't do that. Its nothing like an automatic transmission in its behaviour. Because it isn't an auto.
                        2008 Volkswagen Polo 1.9 TDI
                          if you're in manual mode and you floor it, it wont change gears. if you then push a bit harder the pedal makes a click and it then changes down a gear or two.
                          i've owned a dsg tdi golf for a year and now the gt tdi in manual for 6 months and let me tell you... the dsg is still nothing on the pleasure of driving a manual (the dsg-ers will tell you otherwise though )
                          2x Caddy, 1x Ducato
                            had our 2.0TDI DSG comfortline for 3 years this weekend & touch wood haven't had any issues with the drive train.... it goes like you know what
                            Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
                            2012 BMW X3 MSport 2.0D
                              Originally posted by cogdoc View Post
                              Hi Russ,
                              Thanks to everyone for their feedback. My XR6 is a nice car but I have just replaced the brake rotors all round with aftermarket RDA's and it is already showing signs of light brake shudder again or is it the tailshaft ??? who knows ?? - It's more trouble than it's worth IMO. It also has a suspension bush in the rear gone (at least one) and this is on a car with only 58,000 k's on the clock. I am starting to drool even more about the thought of getting the TDI GT, I was going to test drive a 2.0 TDI Pacific next week, think I'll have to see if they've got a GT as well. I have already been in touch with Jaymz regarding his car and although it would probably be a great car, I am looking at buying new and without all the mods and my preference is for white in colour. I'm pushing 50 and I don't want the neighbours to think I'm having a Mid Life crisis
                              Russ
                              Russ
