Where can I get a gt sport tdi cold air intake from?? I have found a few but well over priced. Is gti the same fit?
Gt sport tdi
I assume you mean for mk5?
All the airboxes are the same.
If you want more hp from this mod, don't bother. You will only get increased noise (if thats what your after).'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I have this one, and it has a LOT of noise, and flutters a lot, lots of fun.
VW Mk5/Mk6 TSI High-Flow Intake System - 42 Draft Designs
Make sure you ask for the pipe with the vacuum "plug".
Originally posted by vraptor View PostI have this one, and it has a LOT of noise, and flutters a lot, lots of fun.
Make sure you ask for the pipe with the vacuum "plug".'07 Touareg V6 TDI with air suspension
'99 A4 Quattro 1.8T
The 42DD intake is not for the faint hearted, people look at you idling at the lights, sounds like Satan breathing. It was actually too much for me to be honest, but for you young ( at heart ) fellas, probably ideal. I don't sell 42DD parts anymore, but easy enough to get direct.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
If you want cool shoo choo noises, remove the rear muffler (replace with straight pipe) and you will get blow off valve like noises when you suddenly come off boost. its quite funny.'07 Touareg V6 TDI with air suspension
'99 A4 Quattro 1.8T
...only on your non-DPF model mate, DPF is the best muffler ever invented.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
