The other day I got a loud beep and 'STOP - CHECK COOLANT' display on my 2007 2.0l TDI BKD. I pulled over and checked the coolant, it seemed fine. Started up and no warnings etc. Read that sometimes the sensors go in the reservoir and figured that must be it. Got another warning the following day and drove home regardless. Tried to start it up the next night to get to work and I got a big clunk then nothing. Tried to start it again and not even the clunk. Check under the bonnet and the reservoir was dry. After work I went and picked up some coolant, filled it up and was very surprised when it only took a litre and a bit. The car started fine (my worries of a seized motor were behind me), turned it off, checked the reservoir and much to my surprise it was empty again. I put another litre or so of coolant in (to the max line), started it again and it drained it again..
I can't see any leaks and there doesn't seem to be any milky stuff under the oil cap. Any idea what might be up with it?
I should add that recently I changed the fuel filter, accidentally spilt some fuel on the serpentine belt and even though I tried to wipe it down it tore shortly after. I replaced it and everything seemed fine. Also, I've had the usual EGR faults since I've had the car and rather than taking it apart/cleaning it I ordered the EGR and cooler delete from Darkside which was going to be installed tomorrow.
Any help would be much appreciated.
