DPF regeneration
  • DPF regeneration
    DPF load is 100.6%.
    Should I enable regeneration by entering code 21295?
    The car may burn down when regenerating with dpf load over 90%.
    Thanks guys.
    Originally posted by snake View Post
    DPF load is 100.6%.
    Thanks guys.
    Car should have stopped driving completely at 90%. Has it been in limp for a while now??
    Never, ever heard of this, and yep, highly likely you will catch fire if that is somehow correct.
      Today I took the car down M5 motoway and carried out a force regeneration. It was successfully cleared the DPF. Started with load 100.6% after 15 mins it was down to 3%. No more limp mode. The warning lights stayed on until I cleared the faults.
      Happy days.
      Thanks for the help and advice.
        At that % it should not have even allowed you to do a DPF burn....Usually if the % is too high then its says it cant be done. The only way I know is to tell the car that a new DPF has been fitted, that Allows the ECU to see zero grams etc and allows the burn at your own risk if fire in the hole!
        BRISBANE / GOLD COAST
          Refer to the below link.
          Forcing DPF regens with Ross Tech VCDS
            My question is what are you reading it with, sounds like it was only actually at 60ish percent, for that is where you can force a regen and lights go out. At 80 the car cuts boost and you are in low boost limp, at 90% the car won't let you start it as far as I know, never gotten that far.
            Just FYI for anyone reading this in future, anything beyond 90% is an absolute fire hazard.
              Haha, last service I had the guys scan and was 85%!.Sent them your DPf removal and clean thread(with photos) for next service which is in 6 weeks. Always liked the Fantastic 4 perhaps i'l be emulating the "Human Torch" in the interim!?
              Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
              Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
                You must have a dodgy sensor then. I was going into limp mode when DPF was 55%. Annoying as hell. As soon as you saw the light, you had about 20km to run a regen or limp mode it was. Then 2 weeks later, same thing again. Replaced both DPF sensors 3 years ago, and only had light come on twice, and never a limp mode again.
                I would suggest that you get the sensors checked if you get high % readings like that. And maybe some Penrite DPF cleaner.
                2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
                2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
                2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
                2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
                  The cars done 206k so probably getting up there, I use the Cleen diesel products on the car which seem pretty good but thanks for recco.
                    Any chance an additive may actually be causing it?.
                    Was it dealer or ,say, Penrite approved?.
                      How is this helpful to the OP?
                      At 206,000km I wouldn't start my diagnose with blaming the additive.
                      Performance Tunes from $850
                      Wrecking RS OCTAVIA 2 Link
                        i didnt.
                        it was a ?
                          If you want to define what can and can't be asked, so be it.
                          I would have thought, on the other hand, any diesel service tech would want to know everything about the patient's diet.
                            Clean Diesel, think they sponsor this site, are Australian and I use the fuel additive and dpf clean stuff. Greg reckons most block up around 100k so i'm thankful of me 206k so far but shes coming off for a proper flush and clean in 3 weeks and hopefully zero scan count?
                              I've said I wouldn't start my diagnose with blaming the additive, meaning I'd already new that the diesel additive was used.
                              On the other hand your post "was the additive dealer approved or Penrite approved" seemed a bit sarcastic to me. That's why I've responded how I responded.
                              My apologies, if you meant something else by wording it that way.
