Exhaust gas warning lamp
  • Exhaust gas warning lamp
    Hi all,
    My exhaust gas warning lamp has lit up on the way home tonight (MKV TDI 2.0L), this has happened once before a few months ago but cleared itself overnight. This happen to anyone else here, if so what is the usual cause and is it anything major to worry about?. I will be ringing dealer in the morning to get it booked in for them to look at. A quick read of the owners handbook seems to point at a possible fault with some kind of exhaust probe?
    I used to be indecisive - now I'm just not sure....
    I am assuming your car is an 08 spec as they come with a DPF (Diesel Particulate Filter)
    Do a search on DPF as it is probably related to that. Diesel Particulate Filters have been a pretty hot topic as they seem to clog up. There is s clearing process where you have to drive for about 15-20 minutes above 2000rpm.
    It should all be in your manual as well.
    SPoddy
    2020 Tiguan 162TSI R-Line
      harr harr harr
      is it a gt sport? if not then you dont have the dpf. and the dpf warning is separate to the other one i think
      2x Caddy, 1x Ducato
        If not a DPF it would then have to be the catalytic converter?
        SPoddy
          faulty sensor?
          2x Caddy, 1x Ducato
            Forgot to mention I have one of those tuning box thingy's installed, took it out last night and light came on again this morning but didn't come on this arvo after work. I now remember doing this last time it happened as well and waited a few weeks before i put the tuning box back in so buggered if I know why it's taken 3 or 4 months to happen again.
              I had the same thing happen to mt brand new 2 tdi comfortline with only 750km on the clock (still the first tank of diesel). The exhaust gas light came on and stayed on with no apparent changes to the way the car drove. It ended up being a sensor unrelated to the exhaust. It had a faulty MAF (air sensor,intake) which was replaced and now the light has gone out. I did notice that before the air sensor was replaced I could hear the turbo and blowoff valve working more easily. Now I can hardly hear the turbo or bov at all. Driving with the new sensor fitted I could feel slighty more torque down low in the rev range as well. It seems that the sensor was probably faulty from new.
                Originally posted by Mischa View Post
                harr harr harr
                My 08 spec TDI comfortline had a DPF
                  negative on that.
                  2x Caddy, 1x Ducato
                    Looking at the current Golf brochure on VWA website, only 125 KW TDI listed as having DPF so Mischa appears to be correct.
                    George
                    14 EOS 2.0 TSI has arrived!
                      No blowoff valve either from what ive read.
                      2.0 TDI Comfortline, 17" VW Factory rims, Bluefin re-flash.
                        George
                        Double Correct.
                          It certainly sounds like a blow off valve (don't most new turbo vehicles have one). Every time I let off the accelerator I could hear the distinctive BOV noise though I can hardly hear it now that the MAF sensor has been replaced. Could someone correct me if I'm wrong, preferably someone with factory manuals to look at. Does the 2.0TDI have a BOV and also what effect would a faulty MAF sensor have on the vehicle. I am just speaking from my own personal experiences. Before the sensor replacement I heard the turbo spool up easier and then a typical BOV noise when lifting off the accelerator (maybe excess boost pressure due to faulty sensor but it didn't have more power though). With new sensor installed I can hardly hear both turbo spooling up or BOV noise. Could someone with some answers please respond.
                            OK - "WARNING - technical content follows".
                            Diesels don't have Blow-Off-Valves (BOVs) because they don't need them and they would reduce engine response/power if you did fit one (I'll explain why later on in this post).
                            BOV's are needed on turbocharged petrol engines because they have throttle/s (moveable plate/s in the intake tract that restrict the amount of air going into the engine and thus the power the engine can make).
                            The one exception to this design that I know of is some BMW petrol motors that achieve the same result (controlling air flow into the motor) by restricting the lift on all the intake valves (it is supposed to reduce pumping losses at part throttle or something)
                            If the turbo is pumping hard then you suddenly back off the accelerator pedal the throttle plate closes off, and the air still being pumped by the turbo now has nowhere to go, thus creating a high pressure spike in the intake. This spike is not good for some engine parts. Most factory petrol turbos have a BOV that vents this excess pressure to the exhaust, but some people like the sound an externally vented one makes, hence the demand for aftermarket BOVs. The BOV can also be used to limit boost (and consequent power and high temps) at full throttle to stop and engine from damaging itself.
                            Diesels don't have a throttle (the amount of power they produce is controlled by how much fuel is injected), so all the air (regardless of boost) just flows through the intake sytem unimpeded all the time, hence no high pressure spikes and thus need for a BOV.
                            If you did install a BOV on a TDI it would need some kind of manual activation mechanism, otherwise it would release the air every time boost pressure got above the pre-determined pressure limit (probably at just the time you wanted maximum power).
                            When you did activate the BOV it would release all the pressurised air in the intake system, and you would have reduced power until you de-activated the BOV and the turbo pumped more air in again.
                            Most VAG TDIs have turbos with moveable vanes, which are moved (controlled by the ECU ) to keep the boost pressure within the desired range.
                            Hope that helps understand some of the differences between how turbo petrols work vs turbo diesels.
                            I'm not sure why your engine sounds different since you replaced the faulty MAF sensor. Maybe the turbo was working much harder to produce the amount of power you were asking for due to the fault ?
                            Any errors or ommissions in the above explanations should be accepted as part of the "pay peanuts, expect monkeys" philosophy of life.
                              Thanks for that handy explanation. I do love a good technical explanation and this one makes sense.
