Its been awhile since since i have posted, as my 2011 1.6 TDI POLO has been running amazingly until last night.....
And so the story beings...... I think i may have a RUNAWAY!
Last night whilst driving my 2011 1.6 TDi Polo, the car decided i was not longer in control and it wanted to continue revving its self (red line pinging) until i put the car in neutral, came to a screeching stop, and turned the ignition off!
To my amazement, the engine continued to run at a ridiculously high RPM after the ignition had been turned off, made 4-5 loud tick/bang noises, then decided to die. Not realising what had just happened, and being in a bit of shock, i got out of the car with the two friends i was with and proceeded to open the bonnet. To my amazement the engine looked fine, fluids were fine, oil was fine, everything looked in order. As i was only a few streets away from my home i decided to try and start the car again. Engine started a bit rough and the moment i tried to drive it, white smoke started pouring out of the exhaust. So i turned the car off again and proceeded to push my Polo home.
Once home i decided to do a bit of research on what had just happened, as one of the friends with me had suggested it might be a RUNAWAY DIESEL! From what i can tell a Runaway Diesel is a rare occurrence where an oil leak (i.e. Turbo, Air intake via crankcase) turns into a feedback loop, constantly over fuelling the engine until it runs faster and faster, thus destroying the engine due to mechanical failure.
So my questions are:
Does my problem sound like a Diesel Runaway that i somehow stopped before it destroyed my engine?
Could it just be a leaky Turbo?
Or am i completely off par, an it might actually have something to do with the Electronic Accelerator?
My beloved Polo is on a tow-truck, on its way back to the dealer as we speak. Fingers crossed, what ever has happened is covered under my warranty!
Everyones help is much appreciated!
Thanks,
Grizzy
Thanks,
Grizzy
