Originally posted by Ryeman
View Post
Battery life of TDI
Good point. Most of the batteries I have bought have had handles built in.Understand how it works, troubleshoot logically BEFORE replacing parts.
Numerous Mk1 Golf diesels
Yuasa are great. Good luck trying to buy a Yuasa automotive battery in Australia though (they only seem to bring in motorcycle/jetski batteries). Ditto Panasonic.Originally posted by Ryeman View PostIf always thought that Yuasa were a good Asian brand.
We had one that lasted from 1976 to 1986 in the first version of the Honda Accord.
how they are handled pre sale is important IMO.
Never use terminal straps to carry/install as that is likely to break the gas seal twixt case and terminal leading to permanent corrosion problems.
Isn't Yuasa American?carandimage The place where Off-Topic is On-Topic
Pretty sure it's Japanese unless the yanks bought them out. The 1976 Accord would have been all Japanese I think.Originally posted by brad View PostYuasa are great. Good luck trying to buy a Yuasa automotive battery in Australia though (they only seem to bring in motorcycle/jetski batteries). Ditto Panasonic.
I noticed them at Battery World the other day but not sure if they are only cycle/marine only.
I deal a lot in gel /agm batteries in my job so get to play with 100s of top quality batteries. I don't believe any gel battery will out last or survive as long as a wet ( flooded) battery when mounted in the engine bay. The heat and resulting in correct charging voltage kills them in months.
I also expect cars running start/stop will have different battery life. A good heavy duty battery should last longer and not circum to sulphation. But a cheap battery with thin paste plates may die early from 100s of extra starts a month.
I can confirm the TDI, especially with DPF regens is a early death sentence to smaller AGM / Gel batteries. Since ditching the massive stock battery early on I've killed two Deka's, an Optima, and am now on my second Braille. The heat from the DPF cycle cooks them, and I've finally worked out some decent insulation and regular 14.4 volt external top up charges are essential to extend the AGM batteries lifespan. I would have gone back to a mammoth wet battery, but I like the space a small battery gives me.
Friggen expensive exercise!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
I got 6.5 years out of mine, and 110,xxxkm. Ended up going with a Bosch battery, as dads needed replacing in the Jetta too, so got a discount for buying 2
Both had similar KM's on them and the Jetta is almost 1.5yrs older.
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
Apologies for the late reply, I picked up the Varta Blue for $219, the blue series have slightly better specs than the original battery fitted.Originally posted by jets View PostI just received a quote for a Besco brand [Malaysia] DIN 65 LH for $134. The Bosch over here is $219 or $250 for the Premium. I didn't find a price for Varta but I believe it to be similar to Bosch. How much was yours?
The main reason I went for that is that it's hard to find anything decent these days that lasts longer than the warranty period and considering the alternative was a Century or Exide for more or less the same price, the Varta was a no brainer.
Just bringing up my old thread.
Purchased new battery today for Jetta , Century made in Australia.($200) (some places in sydney have same for $175)
Did not buy it because the Jetta battery failed but my ute one did after 9 years (besco australian made)
so the jetta battery has now gone into the ute.
Last three services on the jetta I have been told the battery needs replacing.Last edited by neil; 03-08-2015, 11:17 PM.
